I am using v1.14 and trying to model a Fan coil unit with fan operating on a schedule- unfortunately, the osm file does done have supply air fan operating mode field that makes it relevant to operate the unit at that schedule and cycle it per demand at other hours. It is only operating as either run as constant(24X7) or cycling it on demand(OA cycles as well!!!!). How can I get this to work? The following text is from energy plus i had edited to make it work. I prefer to stay in the open studio platform inorder to run parametrics using PAT. Please help!!!!
ZoneHVAC:FourPipeFanCoil, Zone HVAC Four Pipe Fan Coil 64, !- Name Res Common area(OA), !- Availability Schedule Name ConstantFanVariableFlow, !- Capacity Control Method Autosize, !- Maximum Supply Air Flow Rate {m3/s} 1, !- Low Speed Supply Air Flow Ratio 1, !- Medium Speed Supply Air Flow Ratio Autosize, !- Maximum Outdoor Air Flow Rate {m3/s} Res Common area(OA), !- Outdoor Air Schedule Name Node 571, !- Air Inlet Node Name Node 572, !- Air Outlet Node Name OutdoorAir:Mixer, !- Outdoor Air Mixer Object Type Zone HVAC Four Pipe Fan Coil 64 OA Mixer, !- Outdoor Air Mixer Name Fan:OnOff, !- Supply Air Fan Object Type Fan On Off 64, !- Supply Air Fan Name Coil:Cooling:Water, !- Cooling Coil Object Type Coil Cooling Water 64, !- Cooling Coil Name Autosize, !- Maximum Cold Water Flow Rate {m3/s} , !- Minimum Cold Water Flow Rate {m3/s} , !- Cooling Convergence Tolerance Coil:Heating:Water, !- Heating Coil Object Type Coil Heating Water 64, !- Heating Coil Name Autosize, !- Maximum Hot Water Flow Rate {m3/s} , !- Minimum Hot Water Flow Rate {m3/s} , !- Heating Convergence Tolerance , !- Availability Manager List Name , !- Design Specification ZoneHVAC Sizing Object Name Res Common area(OA); !- Supply Air Fan Operating Mode Schedule Name
