Hi,
I’m actually have some difficulties to use the Weather Converter to split the global into direct normal and diffuse horizontal values.
I read on the Auxiliary Programs document and on Unmet hours on these posts:
Link 1: Which data from the weather file is used by OpenStudio to run radiance simulations
Link 2: How can I use EnergyPlus weather converter to split global radiation in to direct normal and diffuse horizontal radiation
Unfortunately, I didn’t understand how to proceed.
In my case, I have global values from an extern file and I want to split it with the Weather Converter.
Someone has an easier way to explain how to proceed?
Thank you,
