Hi guys I want to create heating and cooling performance data for my geothermal heat pump model (Atlas AT 060). I using TRNSYS 16 and TESS V2 with Type 505b geothermal heat pump. I can't find Values of Airflow and Values of Liquid Flow Rate on below catalog. It should be like: 283.14 330.33 !Values of Airflow in liters per second (l/s) 0.19 0.28 0.38 !Values of Liquid Flow Rate in liters per second (l/s) 10.00 21.11 32.22 43.33 !Values of Entering Liquid Temperature (degrees C) 7.12 5.13 1.05 !Total Cooling(kW) Sensible Cooling(kW) and Power(kW) at 283.14/0.19/10 And so on (this is for cooling performance). Can you help me with data from catalog. Thanks The catalog Address: https://dl1.shatelland.com/files/911bef7e-a988-4bf1-9717-f0d650a25aa6/79b3eea0-0fcf-4ff6-8f81-faf39163803c
