I need to model a HP in AHU with water source geothermal as a heat sink. However, in OS the WSHP is only available in zone terminal units, not in central AHU. Any suggestions how to model that ?
Thanks
| 1 | initial version |
Thanks
ThanksUpdate:b
I am thinking about a work around that set up two separate chilled water and hot water loop with vertical bore field or plant load profile. Any comments ?
(/upfiles/1495665876949677.png)
Update:b
| 4 | retagged |
Update:b
