PAT 2.1 and 2.1.1 Impossible to do its job, stops after appliying measures.
I'm using PAT to perform some analisys but a Can't get it to work.
I'm following exctly all the videos on PAT 2.1 amb also I checked tha the OSM file works fine and also the measure that I'm aplliying works fine with Open studio. Also the server works fine and there are not spaces in the directori where PAT is installled, nor the seed files.
The program starts to run fine, also the server works fine, but once the measure is apllied the simulation is not executed, status --> Completed Fail.
I tested PAT2.1 and 2.1.1 and I get the same issue.
In the results page I go to view analisis and Results / data point fields and next to "sdp_log_file" I clik on Togle view and I get all this report (In BOLD Letters It says ERROR):
[13:02:29.424604 INFO] openstudio_2 = true [13:02:29.427617 INFO] openstudio_dir = C:/openstudio-2.1.1/Ruby [13:02:29.427617 INFO] Initializing directory C:/SIMULACIONS/PATTEST/temp_data/analysis_96e95b40-61f1-40a9-9279-ecea38594e1a/data_point_5990d19b-a41f-4aa5-95d3-0ca3359c3f6e/run for simulation with options {:debug=>true, :preserve_run_dir=>true, :profile=>false, :targets=>[#], :cleanup=>true, :energyplus_path=>nil, :verify_osw=>true, :weather_file=>"ESP_Barcelona.081810_SWEC.epw"} [13:02:29.427617 INFO] Starting workflow in C:/SIMULACIONS/PATTEST/temp_data/analysis_96e95b40-61f1-40a9-9279-ecea38594e1a/data_point_5990d19b-a41f-4aa5-95d3-0ca3359c3f6e/run [13:02:29.428615 INFO] Current state: 'queued' [13:02:29.428615 INFO] Next state will be: 'initialization' [13:02:31.436962 DEBUG] RunInitialization passed the following options {:verify_osw=>true, :debug=>true, :preserve_run_dir=>true, :profile=>false, :targets=>[#], :cleanup=>true, :energyplus_path=>nil, :weather_file=>"ESP_Barcelona.081810_SWEC.epw"} [13:02:31.436962 DEBUG] RunInitialization passed the following registry {:openstudio_2=>true, :osw_path=>#, :osw_dir=>#, :run_dir=>#, :log_targets=>[#], :logger=>#, @formatter=nil, @logdev=#]>, @mutex=#>>>} [13:02:31.436962 INFO] Calling perform in the RunInitialization class [13:02:31.437967 DEBUG] Registering that the workflow has started with the adapter [13:02:31.441977 DEBUG] Retrieved the workflow from the adapter [13:02:31.441977 DEBUG] osw_dir is C:/SIMULACIONS/PATTEST/temp_data/analysis_96e95b40-61f1-40a9-9279-ecea38594e1a/data_point_5990d19b-a41f-4aa5-95d3-0ca3359c3f6e [13:02:31.443982 DEBUG] Found associated OSA file [13:02:31.447993 DEBUG] The root_dir for the datapoint is C:/SIMULACIONS/PATTEST/temp_data/analysis_96e95b40-61f1-40a9-9279-ecea38594e1a/data_point_5990d19b-a41f-4aa5-95d3-0ca3359c3f6e [13:02:31.452076 DEBUG] Initialized runner [13:02:31.452076 INFO] Attempting to validate the measure workflow [13:02:31.455138 DEBUG] Validating step 0 [13:02:31.461103 DEBUG] Validated step 0 [13:02:31.461103 INFO] Validated the measure workflow [13:02:31.461103 DEBUG] Finding and loading the seed file [13:02:31.464110 INFO] Loading OSM model [13:02:31.464110 INFO] Reading in OSM model C:/SIMULACIONS/PATTEST/temp_data/analysis_96e95b40-61f1-40a9-9279-ecea38594e1a/seeds/PISA15.osm [13:02:32.146029 DEBUG] Getting the initial weather file [13:02:32.146367 DEBUG] Searching for weather file #{weather_path} [13:02:32.148611 INFO] Current state: 'initialization' [13:02:32.148611 INFO] Next state will be: 'os_measures' [13:02:34.157372 DEBUG] RunOpenStudioMeasures passed the following options {:debug=>true, :preserve_run_dir=>true, :profile=>false, :targets=>[#], :cleanup=>true, :energyplus_path=>nil, :verify_osw=>true, :weather_file=>"ESP_Barcelona.081810_SWEC.epw"} [13:02:34.163387 DEBUG] RunOpenStudioMeasures passed the following registry {:openstudio_2=>true, :osw_path=>#, :osw_dir=>"C:/SIMULACIONS/PATTEST/temp_data/analysis_96e95b40-61f1-40a9-9279-ecea38594e1a/data_point_5990d19b-a41f-4aa5-95d3-0ca3359c3f6e", :run_dir=>#, :log_targets=>[#], :logger=>#, @formatter=nil, @logdev=#]>, @mutex=#>>>, :workflow=>{:seed_file=>"PISA15.osm", :weather_file=>"ESP_Barcelona.081810_SWEC.epw", :file_format_version=>"0.0.1", :osa_id=>"96e95b40-61f1-40a9-9279-ecea38594e1a", :osd_id=>"5990d19b-a41f-4aa5-95d3-0ca3359c3f6e", :created_at=>"2017-05-12 13:02:29 +0200", :measure_paths=>["../measures"], :file_paths=>["../weather", "../seeds", "../seed"], :run_directory=>"./run", :steps=>[{:measure_dir_name=>"861c42ba-2105-49e6-b727-9fc3567f4834", :arguments=>{:building_summary_section=>true, :annual_overview_section=>true, :monthly_overview_section=>true, :utility_bills_rates_section=>true, :envelope_section_section=>true, :space_type_breakdown_section=>true, :space_type_details_section=>true, :interior_lighting_section=>true, :plug_loads_section=>true, :exterior_light_section=>true, :water_use_section=>true, :hvac_load_profile=>true, :zone_condition_section=>true, :zone_summary_section=>true, :zone_equipment_detail_section=>true, :air_loops_detail_section=>true, :plant_loops_detail_section=>true, :outdoor_air_section=>true, :cost_summary_section=>true, :source_energy_section=>true, :schedules_overview_section=>true}, :name=>"Option 1 Name", :description=>"Option 1 Description: This measure creates high level tables and charts pulling both from model inputs and EnergyPlus results. It has building level information as well as detail on space types, thermal zones, HVAC systems, envelope characteristics, and economics. Click the heading above a chart to view a table of the chart data.", :measure_id=>"a25386cd-60e4-46bc-8b11-c755f379d916", :version_id=>"861c42ba-2105-49e6-b727-9fc3567f4834", :taxonomy=>"Reporting.QAQC", :measure_type=>"ReportingMeasure"}], :name=>"Alternative 1", :description=>"Autogenerated 0"}, :datapoint=>nil, :analysis=>{:analysis=>{:_id=>"96e95b40-61f1-40a9-9279-ecea38594e1a", :created_at=>"2017-05-12T11:02:25.649Z", :description=>nil, :display_name=>"PATTEST", :exit_on_guideline14=>false, :file_format_version=>1, :iteration=>-1, :name=>"PATTEST", :os_metadata=>nil, :output_variables=>nil, :problem=>{:workflow=>[{:name=>"openstudio_results", :display_name=>"OpenStudio Results", :measure_type=>"ReportingMeasure", :measure_definition_class_name=>"OpenStudioResults", :measure_definition_directory=>"./measures/861c42ba-2105-49e6-b727-9fc3567f4834", :measure_definition_directory_local=>"C:\SIMULACIONS\PATTEST\measures\861c42ba-2105-49e6-b727-9fc3567f4834", :measure_definition_display_name=>"OpenStudio Results", :measure_definition_name=>"openstudio_results", :measure_definition_name_xml=>nil, :measure_definition_uuid=>"a25386cd-60e4-46bc-8b11-c755f379d916", :measure_definition_version_uuid=>"861c42ba-2105-49e6-b727-9fc3567f4834", :uuid=>"aa027aea-b710-4348-a8cb-bacfb6c27b0b", :version_uuid=>"861c42ba-2105-49e6-b727-9fc3567f4834", :description=>"This measure creates high level tables and charts pulling both from model inputs and EnergyPlus results. It has building level information as well as detail on space types, thermal zones, HVAC systems, envelope characteristics, and economics. Click the heading above a chart to view a table of the chart data.", :taxonomy=>"Reporting.QAQC", :arguments=>nil, :variables=>[{:argument=>{:display_name=>"Model Summary", :display_name_short=>"building_summary_section", :name=>"building_summary_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"f4f32e20-c594-44ae-87e2-1cc5a34928ba"}, :display_name=>"Model Summary", :display_name_short=>"Model Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"55a69039-85b2-44d8-899b-91a2219ffa94", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>0}, {:argument=>{:display_name=>"Annual Overview", :display_name_short=>"annual_overview_section", :name=>"annual_overview_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"add10f14-c492-41af-bafc-e842ca9bc193"}, :display_name=>"Annual Overview", :display_name_short=>"Annual Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"581a7704-2b38-4eb3-a709-ab3956e94513", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>1}, {:argument=>{:display_name=>"Monthly Overview", :display_name_short=>"monthly_overview_section", :name=>"monthly_overview_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"0c897652-f066-4c31-93e2-5595f1a46b43"}, :display_name=>"Monthly Overview", :display_name_short=>"Monthly Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"4a81d79a-056e-4d25-aac1-0eeeb4773116", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>2}, {:argument=>{:display_name=>"Utility Bills/Rates", :display_name_short=>"utility_bills_rates_section", :name=>"utility_bills_rates_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"5b658050-d672-4d33-8e80-e938ed84c8d0"}, :display_name=>"Utility Bills/Rates", :display_name_short=>"Utility Bills/Rates", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"e38733b5-f5e0-4715-b37c-321fe4d1c247", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>3}, {:argument=>{:display_name=>"Envelope", :display_name_short=>"envelope_section_section", :name=>"envelope_section_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"ca84a6d9-870d-46e4-ba99-aefc198215bc"}, :display_name=>"Envelope", :display_name_short=>"Envelope", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"fb083ee6-01e0-494e-a9b4-c1331a8b8242", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>4}, {:argument=>{:display_name=>"Space Type Breakdown", :display_name_short=>"space_type_breakdown_section", :name=>"space_type_breakdown_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"4a67ea50-e08b-48af-90f7-a60d5867d4d0"}, :display_name=>"Space Type Breakdown", :display_name_short=>"Space Type Breakdown", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"531cbfee-c628-41ff-9f1a-6668d3217bdb", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>5}, {:argument=>{:display_name=>"Space Type Summary", :display_name_short=>"space_type_details_section", :name=>"space_type_details_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"b250d36b-b8d0-41ba-ae2f-acdf996bcf70"}, :display_name=>"Space Type Summary", :display_name_short=>"Space Type Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"dd990935-07eb-4082-82bb-aeecbab433d8", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>6}, {:argument=>{:display_name=>"Interior Lighting Summary", :display_name_short=>"interior_lighting_section", :name=>"interior_lighting_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"7c5fb059-6a90-40b2-88d6-7fa8cf058f82"}, :display_name=>"Interior Lighting Summary", :display_name_short=>"Interior Lighting Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"fb371a13-f049-4c3d-bba1-b701d02e769c", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>7}, {:argument=>{:display_name=>"Plug Loads Summary", :display_name_short=>"plug_loads_section", :name=>"plug_loads_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"ffb960cb-fde7-41d9-9bf6-4a000652a793"}, :display_name=>"Plug Loads Summary", :display_name_short=>"Plug Loads Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"61bbe6ee-14d2-4903-b06e-e26b80c39d77", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>8}, {:argument=>{:display_name=>"Exterior Lighting", :display_name_short=>"exterior_light_section", :name=>"exterior_light_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"078e1b24-fbdb-46c8-b54b-9137edf537f9"}, :display_name=>"Exterior Lighting", :display_name_short=>"Exterior Lighting", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"e609220f-dbb1-40c6-8d4b-ff85661f1aa8", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>9}, {:argument=>{:display_name=>"Water Use Equipment", :display_name_short=>"water_use_section", :name=>"water_use_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"ed4671b5-6f0a-4402-a5b2-9c66d5745946"}, :display_name=>"Water Use Equipment", :display_name_short=>"Water Use Equipment", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"eb46ffc0-69df-4d25-89b5-a14488bfaaa9", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>10}, {:argument=>{:display_name=>"HVAC Load Profiles", :display_name_short=>"hvac_load_profile", :name=>"hvac_load_profile", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"a4fc088a-511a-4945-adf4-1a67c231e5fd"}, :display_name=>"HVAC Load Profiles", :display_name_short=>"HVAC Load Profiles", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"781ea98b-e15b-4253-9524-c21043740077", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>11}, {:argument=>{:display_name=>"Zone Conditions", :display_name_short=>"zone_condition_section", :name=>"zone_condition_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"d4b97b60-356d-44e5-8b76-450d3fd8663d"}, :display_name=>"Zone Conditions", :display_name_short=>"Zone Conditions", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"42892544-6fca-4938-a808-e282e15fd1e8", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>12}, {:argument=>{:display_name=>"Zone Overview", :display_name_short=>"zone_summary_section", :name=>"zone_summary_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"a68ffa58-b93f-4ce1-8016-7fe43d31db67"}, :display_name=>"Zone Overview", :display_name_short=>"Zone Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"22e22789-57d7-4822-8879-d6dac2e928b1", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>13}, {:argument=>{:display_name=>"Zone Equipment Detail", :display_name_short=>"zone_equipment_detail_section", :name=>"zone_equipment_detail_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"4cd202ef-b152-46c6-96b2-916cee576002"}, :display_name=>"Zone Equipment Detail", :display_name_short=>"Zone Equipment Detail", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"8775bc1e-f8dd-43d7-943d-17c62e4f90a3", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>14}, {:argument=>{:display_name=>"Air Loops Detail", :display_name_short=>"air_loops_detail_section", :name=>"air_loops_detail_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"4dd77fc7-9c3a-45db-b7df-fb004914993d"}, :display_name=>"Air Loops Detail", :display_name_short=>"Air Loops Detail", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"965d6fc9-7171-4f7c-a1fe-cd7c57138272", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>15}, {:argument=>{:display_name=>"Plant Loops Detail", :display_name_short=>"plant_loops_detail_section", :name=>"plant_loops_detail_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"aa80c2c2-4b8e-426a-af25-c6ee1f2846bb"}, :display_name=>"Plant Loops Detail", :display_name_short=>"Plant Loops Detail", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"137f220a-3b4e-43ed-87a2-33d2b200d642", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>16}, {:argument=>{:display_name=>"Outdoor Air", :display_name_short=>"outdoor_air_section", :name=>"outdoor_air_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"d48bda65-0296-455f-8b47-45136e691095"}, :display_name=>"Outdoor Air", :display_name_short=>"Outdoor Air", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"268f33f7-b2d6-4205-9503-565b749e6f92", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>17}, {:argument=>{:display_name=>"Cash Flow", :display_name_short=>"cost_summary_section", :name=>"cost_summary_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"c9099729-73ce-469e-bb43-5e0c0f4e2fab"}, :display_name=>"Cash Flow", :display_name_short=>"Cash Flow", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"79a887ba-212f-4319-9e80-0ec2d392fcf1", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>18}, {:argument=>{:display_name=>"Site and Source Summary", :display_name_short=>"source_energy_section", :name=>"source_energy_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"16b87209-bdb1-49d8-ac9c-546c6126c071"}, :display_name=>"Site and Source Summary", :display_name_short=>"Site and Source Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"99809b7c-1165-4d36-8b80-1240a7da95ef", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>19}, {:argument=>{:display_name=>"Schedule Overview", :display_name_short=>"schedules_overview_section", :name=>"schedules_overview_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"8c082ba0-e2db-43fb-9de7-641ca86859f6"}, :display_name=>"Schedule Overview", :display_name_short=>"Schedule Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"5c23758c-b05d-439c-83da-2d2cfa5cd3d3", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>20}], :workflow_index=>0}], :algorithm=>{:objective_functions=>nil}, :analysis_type=>nil, :design_alternatives=>[{:name=>"Alternative 1", :options=>[{:measure_name=>"openstudio_results", :workflow_index=>0, :name=>"Option 1 Name", :description=>"Option 1 Description: This measure creates high level tables and charts pulling both from model inputs and EnergyPlus results. It has building level information as well as detail on space types, thermal zones, HVAC systems, envelope characteristics, and economics. Click the heading above a chart to view a table of the chart data."}]}]}, :project_id=>"b320b21a-c287-4132-8e20-e79078ad24a0", :results=>{:batch_datapoints=>{}, :batch_run=>{}}, :run_flag=>true, :samples=>nil, :seed=>{:file_type=>"OSM", :path=>"./seeds/PISA15.osm"}, :seed_zip_content_type=>"application/zip", :seed_zip_file_name=>"PATTEST.zip", :seed_zip_file_size=>1541125, :seed_zip_fingerprint=>"005361e468278a6b9f25eb3c815445ae", :seed_zip_updated_at=>"2017-05-12T11:02:25.839+00:00", :server_scripts=>{}, :status_message=>"", :updated_at=>"2017-05-12T11:02:26.590Z", :uuid=>"96e95b40-61f1-40a9-9279-ecea38594e1a", :version_uuid=>nil, :weather_file=>{:file_type=>"EPW", :path=>"./weather/ESP_Barcelona.081810_SWEC.epw"}}}, :workflow_json=>#, :root_dir=>#, :runner=>#, @formatter=nil, @logdev=#]>, @mutex=#>>>, @workflow_json=#, @openstudio_2=true, @datapoint=nil, @analysis={:analysis=>{:_id=>"96e95b40-61f1-40a9-9279-ecea38594e1a", :created_at=>"2017-05-12T11:02:25.649Z", :description=>nil, :display_name=>"PATTEST", :exit_on_guideline14=>false, :file_format_version=>1, :iteration=>-1, :name=>"PATTEST", :os_metadata=>nil, :output_variables=>nil, :problem=>{:workflow=>[{:name=>"openstudio_results", :display_name=>"OpenStudio Results", :measure_type=>"ReportingMeasure", :measure_definition_class_name=>"OpenStudioResults", :measure_definition_directory=>"./measures/861c42ba-2105-49e6-b727-9fc3567f4834", :measure_definition_directory_local=>"C:\SIMULACIONS\PATTEST\measures\861c42ba-2105-49e6-b727-9fc3567f4834", :measure_definition_display_name=>"OpenStudio Results", :measure_definition_name=>"openstudio_results", :measure_definition_name_xml=>nil, :measure_definition_uuid=>"a25386cd-60e4-46bc-8b11-c755f379d916", :measure_definition_version_uuid=>"861c42ba-2105-49e6-b727-9fc3567f4834", :uuid=>"aa027aea-b710-4348-a8cb-bacfb6c27b0b", :version_uuid=>"861c42ba-2105-49e6-b727-9fc3567f4834", :description=>"This measure creates high level tables and charts pulling both from model inputs and EnergyPlus results. It has building level information as well as detail on space types, thermal zones, HVAC systems, envelope characteristics, and economics. Click the heading above a chart to view a table of the chart data.", :taxonomy=>"Reporting.QAQC", :arguments=>nil, :variables=>[{:argument=>{:display_name=>"Model Summary", :display_name_short=>"building_summary_section", :name=>"building_summary_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"f4f32e20-c594-44ae-87e2-1cc5a34928ba"}, :display_name=>"Model Summary", :display_name_short=>"Model Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"55a69039-85b2-44d8-899b-91a2219ffa94", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>0}, {:argument=>{:display_name=>"Annual Overview", :display_name_short=>"annual_overview_section", :name=>"annual_overview_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"add10f14-c492-41af-bafc-e842ca9bc193"}, :display_name=>"Annual Overview", :display_name_short=>"Annual Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"581a7704-2b38-4eb3-a709-ab3956e94513", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>1}, {:argument=>{:display_name=>"Monthly Overview", :display_name_short=>"monthly_overview_section", :name=>"monthly_overview_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"0c897652-f066-4c31-93e2-5595f1a46b43"}, :display_name=>"Monthly Overview", :display_name_short=>"Monthly Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"4a81d79a-056e-4d25-aac1-0eeeb4773116", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>2}, {:argument=>{:display_name=>"Utility Bills/Rates", :display_name_short=>"utility_bills_rates_section", :name=>"utility_bills_rates_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"5b658050-d672-4d33-8e80-e938ed84c8d0"}, :display_name=>"Utility Bills/Rates", :display_name_short=>"Utility Bills/Rates", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"e38733b5-f5e0-4715-b37c-321fe4d1c247", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>3}, {:argument=>{:display_name=>"Envelope", :display_name_short=>"envelope_section_section", :name=>"envelope_section_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"ca84a6d9-870d-46e4-ba99-aefc198215bc"}, :display_name=>"Envelope", :display_name_short=>"Envelope", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"fb083ee6-01e0-494e-a9b4-c1331a8b8242", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>4}, {:argument=>{:display_name=>"Space Type Breakdown", :display_name_short=>"space_type_breakdown_section", :name=>"space_type_breakdown_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"4a67ea50-e08b-48af-90f7-a60d5867d4d0"}, :display_name=>"Space Type Breakdown", :display_name_short=>"Space Type Breakdown", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"531cbfee-c628-41ff-9f1a-6668d3217bdb", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>5}, {:argument=>{:display_name=>"Space Type Summary", :display_name_short=>"space_type_details_section", :name=>"space_type_details_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"b250d36b-b8d0-41ba-ae2f-acdf996bcf70"}, :display_name=>"Space Type Summary", :display_name_short=>"Space Type Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"dd990935-07eb-4082-82bb-aeecbab433d8", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>6}, {:argument=>{:display_name=>"Interior Lighting Summary", :display_name_short=>"interior_lighting_section", :name=>"interior_lighting_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"7c5fb059-6a90-40b2-88d6-7fa8cf058f82"}, :display_name=>"Interior Lighting Summary", :display_name_short=>"Interior Lighting Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"fb371a13-f049-4c3d-bba1-b701d02e769c", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>7}, {:argument=>{:display_name=>"Plug Loads Summary", :display_name_short=>"plug_loads_section", :name=>"plug_loads_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"ffb960cb-fde7-41d9-9bf6-4a000652a793"}, :display_name=>"Plug Loads Summary", :display_name_short=>"Plug Loads Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"61bbe6ee-14d2-4903-b06e-e26b80c39d77", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>8}, {:argument=>{:display_name=>"Exterior Lighting", :display_name_short=>"exterior_light_section", :name=>"exterior_light_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"078e1b24-fbdb-46c8-b54b-9137edf537f9"}, :display_name=>"Exterior Lighting", :display_name_short=>"Exterior Lighting", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"e609220f-dbb1-40c6-8d4b-ff85661f1aa8", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>9}, {:argument=>{:display_name=>"Water Use Equipment", :display_name_short=>"water_use_section", :name=>"water_use_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"ed4671b5-6f0a-4402-a5b2-9c66d5745946"}, :display_name=>"Water Use Equipment", :display_name_short=>"Water Use Equipment", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"eb46ffc0-69df-4d25-89b5-a14488bfaaa9", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>10}, {:argument=>{:display_name=>"HVAC Load Profiles", :display_name_short=>"hvac_load_profile", :name=>"hvac_load_profile", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"a4fc088a-511a-4945-adf4-1a67c231e5fd"}, :display_name=>"HVAC Load Profiles", :display_name_short=>"HVAC Load Profiles", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"781ea98b-e15b-4253-9524-c21043740077", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>11}, {:argument=>{:display_name=>"Zone Conditions", :display_name_short=>"zone_condition_section", :name=>"zone_condition_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"d4b97b60-356d-44e5-8b76-450d3fd8663d"}, :display_name=>"Zone Conditions", :display_name_short=>"Zone Conditions", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"42892544-6fca-4938-a808-e282e15fd1e8", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>12}, {:argument=>{:display_name=>"Zone Overview", :display_name_short=>"zone_summary_section", :name=>"zone_summary_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"a68ffa58-b93f-4ce1-8016-7fe43d31db67"}, :display_name=>"Zone Overview", :display_name_short=>"Zone Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"22e22789-57d7-4822-8879-d6dac2e928b1", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>13}, {:argument=>{:display_name=>"Zone Equipment Detail", :display_name_short=>"zone_equipment_detail_section", :name=>"zone_equipment_detail_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"4cd202ef-b152-46c6-96b2-916cee576002"}, :display_name=>"Zone Equipment Detail", :display_name_short=>"Zone Equipment Detail", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"8775bc1e-f8dd-43d7-943d-17c62e4f90a3", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>14}, {:argument=>{:display_name=>"Air Loops Detail", :display_name_short=>"air_loops_detail_section", :name=>"air_loops_detail_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"4dd77fc7-9c3a-45db-b7df-fb004914993d"}, :display_name=>"Air Loops Detail", :display_name_short=>"Air Loops Detail", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"965d6fc9-7171-4f7c-a1fe-cd7c57138272", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>15}, {:argument=>{:display_name=>"Plant Loops Detail", :display_name_short=>"plant_loops_detail_section", :name=>"plant_loops_detail_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"aa80c2c2-4b8e-426a-af25-c6ee1f2846bb"}, :display_name=>"Plant Loops Detail", :display_name_short=>"Plant Loops Detail", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"137f220a-3b4e-43ed-87a2-33d2b200d642", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>16}, {:argument=>{:display_name=>"Outdoor Air", :display_name_short=>"outdoor_air_section", :name=>"outdoor_air_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"d48bda65-0296-455f-8b47-45136e691095"}, :display_name=>"Outdoor Air", :display_name_short=>"Outdoor Air", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"268f33f7-b2d6-4205-9503-565b749e6f92", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>17}, {:argument=>{:display_name=>"Cash Flow", :display_name_short=>"cost_summary_section", :name=>"cost_summary_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"c9099729-73ce-469e-bb43-5e0c0f4e2fab"}, :display_name=>"Cash Flow", :display_name_short=>"Cash Flow", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"79a887ba-212f-4319-9e80-0ec2d392fcf1", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>18}, {:argument=>{:display_name=>"Site and Source Summary", :display_name_short=>"source_energy_section", :name=>"source_energy_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"16b87209-bdb1-49d8-ac9c-546c6126c071"}, :display_name=>"Site and Source Summary", :display_name_short=>"Site and Source Summary", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"99809b7c-1165-4d36-8b80-1240a7da95ef", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>19}, {:argument=>{:display_name=>"Schedule Overview", :display_name_short=>"schedules_overview_section", :name=>"schedules_overview_section", :value_type=>"boolean", :default_value=>true, :value=>true, :uuid=>"8c082ba0-e2db-43fb-9de7-641ca86859f6"}, :display_name=>"Schedule Overview", :display_name_short=>"Schedule Overview", :variable_type=>"variable", :units=>"", :minimum=>true, :maximum=>true, :relation_to_output=>nil, :static_value=>true, :uuid=>"5c23758c-b05d-439c-83da-2d2cfa5cd3d3", :version_uuid=>"", :variable=>true, :uncertainty_description=>{:type=>"discrete", :attributes=>[{:name=>"discrete", :values_and_weights=>[{:value=>true, :weight=>1}]}, {:name=>"lower_bounds", :value=>true}, {:name=>"upper_bounds", :value=>true}, {:name=>"modes", :value=>1}, {:name=>"delta_x", :value=>nil}, {:name=>"stddev", :value=>nil}]}, :workflow_index=>20}], :workflow_index=>0}], :algorithm=>{:objective_functions=>nil}, :analysis_type=>nil, :design_alternatives=>[{:name=>"Alternative 1", :options=>[{:measure_name=>"openstudio_results", :workflow_index=>0, :name=>"Option 1 Name", :description=>"Option 1 Description: This measure creates high level tables and charts pulling both from model inputs and EnergyPlus results. It has building level information as well as detail on space types, thermal zones, HVAC systems, envelope characteristics, and economics. Click the heading above a chart to view a table of the chart data."}]}]}, :project_id=>"b320b21a-c287-4132-8e20-e79078ad24a0", :results=>{:batch_datapoints=>{}, :batch_run=>{}}, :run_flag=>true, :samples=>nil, :seed=>{:file_type=>"OSM", :path=>"./seeds/PISA15.osm"}, :seed_zip_content_type=>"application/zip", :seed_zip_file_name=>"PATTEST.zip", :seed_zip_file_size=>1541125, :seed_zip_fingerprint=>"005361e468278a6b9f25eb3c815445ae", :seed_zip_updated_at=>"2017-05-12T11:02:25.839+00:00", :server_scripts=>{}, :status_message=>"", :updated_at=>"2017-05-12T11:02:26.590Z", :uuid=>"96e95b40-61f1-40a9-9279-ecea38594e1a", :version_uuid=>nil, :weather_file=>{:file_type=>"EPW", :path=>"./weather/ESP_Barcelona.081810_SWEC.epw"}}}>, :model=>#, :wf=>"C:/SIMULACIONS/PATTEST/temp_data/analysis_96e95b40-61f1-40a9-9279-ecea38594e1a/weather/ESP_Barcelona.081810_SWEC.epw"} [13:02:34.164428 DEBUG] Calling perform in the RunOpenStudioMeasures class [13:02:34.278254 INFO] Beginning to execute OpenStudio measures. [13:02:34.278254 DEBUG] Finding measures of type ModelMeasure [13:02:34.282269 DEBUG] Passing measure OpenStudioResults of type ModelMeasure [13:02:34.282269 INFO] Finished applying OpenStudio measures. [13:02:34.283273 DEBUG] Communicating measure output attributes to the output adapter *[13:02:34.421897 ERROR] Found error in state 'os_measures' with message ["\"\xC3\" from ASCII-8BIT to UTF-8:C:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-*1.2.2/lib/openstudio/workflow/util/model.rb:81:in write'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.2.2/lib/openstudio/workflow/util/model.rb:81:in<<'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.2.2/lib/openstudio/workflow/util/model.rb:81:in block in save_osm'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.2.2/lib/openstudio/workflow/util/model.rb:81:inopen'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.2.2/lib/openstudio/workflow/util/model.rb:81:in save_osm'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.2.2/lib/openstudio/workflow/jobs/run_os_measures.rb:58:inperform'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.2.2/lib/openstudio/workflow/run.rb:256:in step'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.2.2/lib/openstudio/workflow/run.rb:210:inrun'\nC:/openstudio-2.1.1/pat/OpenStudio-server/server/app/workers/run_simulate_data_point.rb:173:in block in perform'\nC:/openstudio-2.1.1/pat/OpenStudio-server/server/app/workers/run_simulate_data_point.rb:168:inopen'\nC:/openstudio-2.1.1/pat/OpenStudio-server/server/app/workers/run_simulate_data_point.rb:168:in perform'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/performable_method.rb:26:inperform'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/backend/base.rb:84:in block in invoke_job'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:in block in initialize'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:in execute'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:40:inrun_callbacks'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/backend/base.rb:81:in invoke_job'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:230:inblock (2 levels) in run'\nC:/openstudio-2.1.1/pat/ruby/lib/ruby/2.2.0/timeout.rb:88:in block in timeout'\nC:/openstudio-2.1.1/pat/ruby/lib/ruby/2.2.0/timeout.rb:98:incall'\nC:/openstudio-2.1.1/pat/ruby/lib/ruby/2.2.0/timeout.rb:98:in timeout'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:230:inblock in run'\nC:/openstudio-2.1.1/pat/ruby/lib/ruby/2.2.0/benchmark.rb:303:in realtime'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:229:inrun'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:306:in block in reserve_and_run_one_job'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:in block in initialize'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:in execute'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:40:inrun_callbacks'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:306:in reserve_and_run_one_job'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:213:inblock in work_off'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:212:in times'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:212:inwork_off'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:175:in block (4 levels) in start'\nC:/openstudio-2.1.1/pat/ruby/lib/ruby/2.2.0/benchmark.rb:303:inrealtime'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:174:in block (3 levels) in start'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:in block in initialize'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:in execute'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:40:inrun_callbacks'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:173:in block (2 levels) in start'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:172:inloop'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:172:in block in start'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/plugins/clear_locks.rb:7:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/plugins/clear_locks.rb:7:in block (2 levels) in '\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:79:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:79:in block (2 levels) in add'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:61:in block in initialize'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:79:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:79:in block in add'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:66:in execute'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/lifecycle.rb:40:inrun_callbacks'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/worker.rb:171:in start'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/command.rb:132:inrun'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/command.rb:120:in block in run_process'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/application.rb:266:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/application.rb:266:in block in start_proc'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/application.rb:275:incall'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/application.rb:275:in start_proc'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/application.rb:296:instart'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/controller.rb:59:in run'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons.rb:197:inblock in run_proc'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/cmdline.rb:92:in call'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons/cmdline.rb:92:incatch_exceptions'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/daemons-1.2.4/lib/daemons.rb:196:in run_proc'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/command.rb:118:inrun_process'\nC:/openstudio-2.1.1/pat/OpenStudio-server/gems/gems/delayed_job-4.1.2/lib/delayed/command.rb:94:in daemonize'\nbin/delayed_job:6:in '"]} [13:02:34.422900 INFO] Finished workflow - communicating results and zipping files [13:02:34.672165 INFO] Workflow complete
