Hi!
Based on the idf file which already run successfully, I implemented air side economizer using controller:OutdoorAir. Then I got following error when Check:Sizing:Zone and ZoneControl:Thermostat input are executed.
* Severe * UpdateZoneSizing: Cooling supply air temperature (calculated) within 2C of zone temperature
check zone thermostat set point and design supply air temperatures
zone name = 1F SERVER RM 2
design sensible cooling load = 521720.55 W
thermostat set point temp = 0.000 C
zone temperature = 25.000 C
supply air temperature = 23.000 C
temperature difference = -2.00000 C
calculated volume flow rate = 213.10810 m3/s
calculated mass flow rate = 255.58473 kg/s
I already confirmed that I correctly input thermostat information checking Zone Thermostat Air Temperature from eso file.
Does anyone know why thermostat set point temp=0 deg even though I set thermostat 25 deg?
Thank you!
