DesignBuilder Energy Efficiency Measures
Hello
Does anyone have a suggestion about running Energy Efficiency Measures (EEM/ECMs) in DesignBuilder in an efficient manner? You can create your baseline and manually make each single change, such as change the U-value of roof, one by one in each simulation. But the problem is when your baseline is changed. Your work is wasted when you make a change in your baseline. I want to know if you have any suggestions for this process In DesignBuidler.
Thanks for your help in advance.
Ladan
Hello
Ladan
