My OpenStudio simulation is failing when trying to apply the "OpenStudio Results" measure. I am referring to the one that runs automatically with OS. If I apply the BCL measure of the same name, it runs, but will not show zone conditions. In place of the zone condition section it shows the text below. I seem to have more questions than answers on this forum, but any help would be appreciated.
Zone Conditions section failed and was skipped because: Optional not initialized. Detail on error follows.
["C:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/user_script.rb:158:in eval'\nC:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/resources/os_lib_reporting.rb:2716:in
block in zone_condition_section'\nC:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/resources/os_lib_reporting.rb:2684:in each'\nC:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/resources/os_lib_reporting.rb:2684:in
zone_condition_section'\n(eval):1:in block in run'\nC:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/user_script.rb:158:in
eval'\nC:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/user_script.rb:158:in block in run'\nC:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/user_script.rb:153:in
each'\nC:/Users/timj/AppData/Local/Temp/OpenStudio.y15028/resources/run/6-UserScript-0/mergedjob-0/user_script.rb:153:in run'\nmergedjob-0/in.rb:396:in
