asked 8 years ago
rkbest's avatar
Can I use SEER for 8 TR and more heat pumps?
Recently I was told not to use SEER/EER ratings for heat-pumps of 8 TR capacity (or more) and to check when the rating can be used and not. I am unable to find any literature which suggests the relation of SEER and EER rating with capacity. Any suggestions on this topic.
Recently I was told not to use SEER/EER ratings for heat-pumps of 8 TR capacity (or more) and to check when the rating can be used and not. I am unable to find any literature which suggests the relation limitation of using terms SEER and EER rating with capacity. Any suggestions insights on this topic. topic?
Recently I was told not to use SEER/EER ratings for heat-pumps of 8 TR capacity (or more) and to check when the rating can be used and not. I am unable to find any literature which suggests the limitation of using terms SEER and EER rating with capacity. Any insights on this topic?
