I'm trying to modeling a commercial split air conditioner and heat pump, specifically the model: 38CQD048535MC of Carrier.
The information available for these model is:
I'm using:
- HVACTemplate: Thermostat
- HVACTemplate:System:Unitary
- HVACTemplate:Zone:Unitary
In the HVACTemplate:System:Unitary, there are a lot of fields that I don't have the values for complete, so I'm using the default values giving by energy plus. In the field heating coil type there are three options: electric, gas and hot water. I'm using electric, but I'm not sure if these is the correct way to model the split when is working like a heat pump. For now, I did these:
I would like to know if what I have done is correct or what is the correct way to model these kind of commercial air conditioners.
