I have created a building model using OpenStuido 1.12.0 and SketchUp 2016. The building model is relatively simple and does not include any HVAC equipment at this point. For some reason I am unable to export an .idf file using the OpenStudio plug-in menu within SketchUp. There is no failure prompt given by OS, the .idf file is just simply not created. Furthermore, I am getting this error from the measures tab within the OS App:
And unhandled exception has occured.
E:\Git\OS3\openstudiocore\src\utilities\idf\WorkspaceObject.cpp@835 : Attempt to write a disconnected WrokspaceObject out to Idf.
As is expected, when I try and run the simulation from the run tab within the OS App the run fails at the idf conversion step. A little more background; I originally created the building model on my Mac and did not notice this error until I transfered the .osm file to my PC and tried to export the .idf. (I am running OS 1.12 on my Mac and OS 1.14 on my PC). I went back to my Mac to try and export an .idf as well as use the measures tab and I was getting the same errors.
I searched for quite some time in the hopes that I would find an answer but I still can't figure out what I'm doing wrong/what I can do to fix it. Thank you for any feedback!
