Basically I'm wondering why the values for indoor and outdoor surface temperature aren't changing for this idf file when they should change as accompanied by the change in the enthalpy-temperature curve as described in MaterialProperty:PhaseChange.
I've tested it on the 'CondFD1ZonePurchAirAutoSizeWithPCM.idf' example file and it seems that there weren't any problems with the example file. I'm sure I have the required classes when I compared it against the example file.
For example when I change PCtemp 2 from 20 to 30 and PCtemp3 from 20.1 to 30.1, all the values for the surface temperatures remain the same, they should change but I have no idea why they don't. The example file shows a big difference, this one doesn't and I have no idea why...
https://mega.nz/#!Td8AgLaZ!v426mSD_rFnEaLBGddF3tHFyZoen4aWwt0x98vTUPPg [idf file]
Thank you in advance!
