The error report show that,
* Warning * Calculated design heating load for zone=F1-ADDITIONAL is zero.
* ~~~ * Check Sizing:Zone and ZoneControl:Thermostat inputs.
* Warning * SizeDXCoil Coil:Cooling:DX:VariableRefrigerantFlow ADDITIONAL-1 VRF DX COOLING COIL
* ~~~ * ...Gross Rated Total Cooling Capacity [W] will be limited by the minimum rated volume flow per rated total capacity ratio.
* ~~~ * ...DX coil volume flow rate (m3/s ) = 1.241784 * ~~~ * ...Requested capacity (W ) = 36544.966 * ~~~ * ...Requested flow/capacity ratio (m3/s/W ) = 3.397E-005 * ~~~ * ...Minimum flow/capacity ratio (m3/s/W ) = 4.027E-005 * ~~~ * ...Adjusted capacity ( W ) = 30836.470 I have checked sizing zone and zone control:thermostat, but I fial to solve this problem.
Any suggestion is appreciative
