Hello everyone, I am an engineering student and I am trying to simulate a one store building with all its internal loads and a mechanical ventilation. First of all I do apologize if I type some grammatical error but I am not a native speaker.
I already read a lot of other discussions about this topic and they really helped me to model my building so far. Now I am trying to get deeper into the detail of the mechanical ventilation and I encountered some problems.
I followed this discussion ( https://unmethours.com/question/1766/open-studio-modelling-a-mechanical-ventilation-system-no-coils-and-a-baseboardradiantconvectivewater-system-for-2-zones/ ) to model my mechanical ventilation air loop and mine looks like this ( http://imageshack.com/a/img922/8674/KCsCwK.png )
I assigned a Design Specification Outdoor Air ( m^3/s ) for all my space. ( http://imageshack.com/a/img924/7663/mQ61qd.png ).
I changed some parameters in OS:SizingSystem as ahown in the image. ( http://imageshack.com/a/img924/9236/NBmZsA.png ). Basically I want at least 18 °C during heating and at least 24 °C during cooling time.
I have some questions: - Where can I set the hours during which I want the mechanical ventilation to work? ( I tried to modify the minimum outdoor schedule Name in OS:Controller:OutdoorAir but it doesn't seem working) - Is this all I need to set in order to have the zone air temperature behaviours displayed?
- These are the warnings I got from the simulation: * Warning * ProcessScheduleInput: ScheduleTypeLimits="CONTROLMODE", Unit Type="CONTROLMODE" is invalid.
* Warning * ProcessScheduleInput: ScheduleTypeLimits="LINEARPOWERDENSITY", Unit Type="LINEARPOWERDENSITY" is invalid.
* Warning * ProcessScheduleInput: ScheduleTypeLimits="VOLUMETRICFLOWRATE", Unit Type="VOLUMETRICFLOWRATE" is invalid.
* Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated.
* Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS ON CONTINUOUS", Blank Schedule Type Limits Name input -- will not be validated.
* Warning * UpdateZoneSizing: Cooling supply air temperature (calculated) within 5C of zone temperature * ~~~ * ...check zone thermostat set point and design supply air temperatures * ~~~ * ...zone name = THERMAL ZONE 1 * ~~~ * ...design sensible cooling load = 6197.53 W * ~~~ * ...thermostat set point temp = 0.000 C * ~~~ * ...zone temperature = 23.984 C * ~~~ * ...supply air temperature = 20.000 C * ~~~ * ...temperature difference = -3.98425 C * ~~~ * ...calculated volume flow rate = 1.26792 m3/s * ~~~ * ...calculated mass flow rate = 1.52407 kg/s
* Warning * GetAirPathData: AirLoopHVAC="AIR LOOP HVAC 1" has no Controllers.
Anyone can explain me which errors I should consider and which I should disregard? I would like to know the meaning of the penultimate warning.
Thank you very much. This site is really helpfull and I really appreciate your work.
