Hey all,
Trying to apply the aedg_office_hvac_vav_ch_w measure to my building and I am getting an error. I don't have much to go on, this is a building to which I was able to apply other AEDG measures to (e.g. WSHP w/ DOAS) without any similar problems.
Here is the advanced output from the measure output (apologies for the long text posting I lack the knowledge to even know what of the following is pertinent):
DL is deprecated, please use Fiddle
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:53: [BUG] Segmentation fault
ruby 2.0.0p645 (2015-04-13) [x64-mingw32]
-- Control frame information -----------------------------------------------
c:0011 p:---- s:0128 e:000127 CFUNC :setReturnPlenum
c:0010 p:0151 s:0124 e:000123 BLOCK C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:53 [FINISH]
c:0009 p:---- s:0118 e:000117 CFUNC :each
c:0008 p:0016 s:0115 e:000114 BLOCK C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:43 [FINISH]
c:0007 p:---- s:0111 e:000110 CFUNC :each
c:0006 p:0016 s:0108 e:000107 BLOCK C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:39 [FINISH]
c:0005 p:---- s:0104 e:000103 CFUNC :each
c:0004 p:0078 s:0101 e:000100 METHOD C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:35
c:0003 p:1214 s:0091 e:000090 METHOD C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/user_script.rb:240
c:0002 p:1590 s:0033 E:002490 EVAL in.rb:364 [FINISH]
c:0001 p:0000 s:0002 E:000fd8 TOP [FINISH]
in.rb:364:in `<main>'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/user_script.rb:240:in `run'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:35:in `validateAndAddPlenumZonesToSystem'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:35:in `each'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:39:in `block in validateAndAddPlenumZonesToSystem'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:39:in `each'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:43:in `block (2 levels) in validateAndAddPlenumZonesToSystem'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:43:in `each'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:53:in `block (3 levels) in validateAndAddPlenumZonesToSystem'
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:53:in `setReturnPlenum'
-- C level backtrace information -------------------------------------------
C:\Windows\SYSTEM32\ntdll.dll(ZwWaitForSingleObject+0xa) [0x00007FFB174F06FA]
C:\Windows\system32\KERNELBASE.dll(WaitForSingleObjectEx+0x98) [0x00007FFB14781118]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_vm_bugreport+0x9d) [0x000000006F287B2D]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_name_err_mesg_new+0x838) [0x000000006F1422D8]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_bug+0x45) [0x000000006F143085]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_check_safe_str+0x3c1) [0x000000006F20BF21]
[0x0000000000401A85]
C:\Windows\SYSTEM32\ntdll.dll(_C_specific_handler+0x96) [0x00007FFB174E1D86]
C:\Windows\SYSTEM32\ntdll.dll(_chkstk+0x9d) [0x00007FFB174F33FD]
C:\Windows\SYSTEM32\ntdll.dll(RtlRaiseException+0xf67) [0x00007FFB174B4847]
C:\Windows\SYSTEM32\ntdll.dll(KiUserExceptionDispatcher+0x3a) [0x00007FFB174F258A]
C:\Program Files\OpenStudio 1.13.3\Ruby\openstudio\openstudio_utilities.dll(std::enable_shared_from_this<openstudio::detail::IdfObject_Impl>::shared_from_this+0x12) [0x00007FFAEFA1A4B2]
C:\Program Files\OpenStudio 1.13.3\Ruby\openstudio\openstudio_utilities.dll(openstudio::detail::WorkspaceObject_Impl::workspace+0x3a) [0x00007FFAEFA7B05A]
C:\Program Files\OpenStudio 1.13.3\Ruby\openstudio\openstudio_model.dll(openstudio::model::detail::ModelObject_Impl::model+0x29) [0x00007FFAEBDBF129]
C:\Program Files\OpenStudio 1.13.3\Ruby\openstudio\openstudio_model.dll(openstudio::model::detail::AirLoopHVACReturnPlenum_Impl::addToNode+0x5d) [0x00007FFAEBE2C35D]
C:\Program Files\OpenStudio 1.13.3\Ruby\openstudio\openstudio_model.dll(openstudio::model::AirLoopHVACReturnPlenum::addToNode+0x36) [0x00007FFAEBE2C2B6]
C:\Program Files\OpenStudio 1.13.3\Ruby\openstudio\openstudio_model.dll(openstudio::model::detail::ThermalZone_Impl::setReturnPlenum+0x3dd) [0x00007FFAEC3BABDD]
C:\Program Files\OpenStudio 1.13.3\Ruby\openstudio\openstudio_model.dll(openstudio::model::ThermalZone::setReturnPlenum+0x32) [0x00007FFAEC3BA7C2]
[0x00007FFAEA45A110]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_error_arity+0x125) [0x000000006F272615]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_vm_localjump_error+0x1cf8) [0x000000006F276D08]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_vm_localjump_error+0x5bf9) [0x000000006F27AC09]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_yield+0x178) [0x000000006F284638]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_ary_each+0x51) [0x000000006F106871]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_vm_localjump_error+0x1c91) [0x000000006F276CA1]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_f_send+0x5a1) [0x000000006F2817C1]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_iseq_eval_main+0x1e0) [0x000000006F284CA0]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(rb_check_copyable+0x3287) [0x000000006F148047]
C:\Program Files\OpenStudio 1.13.3\ruby-install\ruby\bin\x64-msvcrt-ruby200.dll(ruby_run_node+0x51) [0x000000006F14A8C1]
[0x0000000000402D14]
[0x00000000004013D7]
[0x00000000004014F8]
C:\Windows\system32\KERNEL32.DLL(BaseThreadInitThunk+0x22) [0x00007FFB170113D2]
-- Other runtime information -----------------------------------------------
* Loaded script: in.rb
* Loaded features:
0 enumerator.so
1 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/enc/encdb.so
2 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/enc/iso_8859_1.so
3 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/enc/trans/transdb.so
4 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/rbconfig.rb
5 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/compatibility.rb
6 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/defaults.rb
7 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/deprecate.rb
8 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/errors.rb
9 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/version.rb
10 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/requirement.rb
11 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/platform.rb
12 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/specification.rb
13 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/exceptions.rb
14 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/defaults/operating_system.rb
15 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/enc/utf_16le.so
16 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/enc/trans/utf_16_32.so
17 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/core_ext/kernel_gem.rb
18 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/thread.rb
19 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/monitor.rb
20 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb
21 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/rubygems.rb
22 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/pathname.so
23 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/pathname.rb
24 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/enc/trans/single_byte.so
25 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/dl.so
26 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/x64-mingw32/fiddle.so
27 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/fiddle/function.rb
28 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/fiddle/closure.rb
29 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/fiddle.rb
30 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/dl.rb
31 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/Win32API.rb
32 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiescore.so
33 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiestime.so
34 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesdata.so
35 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesplot.so
36 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesgeometry.so
37 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiessql.so
38 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesbcl.so
39 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiescloud.so
40 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesunits.so
41 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesidd.so
42 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesidf.so
43 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilitiesfiletypes.so
44 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioutilities.so
45 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodel.so
46 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodelcore.so
47 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodelsimulation.so
48 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodelresources.so
49 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodelgeometry.so
50 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodelhvac.so
51 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodelrefrigeration.so
52 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodelgenerators.so
53 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioenergyplus.so
54 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioradiance.so
55 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiogbxml.so
56 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioairflow.so
57 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioosversion.so
58 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioruleset.so
59 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiorunmanager.so
60 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioproject.so
61 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioanalysisdriver.so
62 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiomodeleditor.so
63 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioanalysis.so
64 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiolib.so
65 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudioisomodel.so
66 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio/openstudiosdd.so
67 C:/Program Files/OpenStudio 1.13.3/Ruby/openstudio.rb
68 C:/Program Files/OpenStudio 1.13.3/ruby-install/ruby/lib/ruby/2.0.0/optparse.rb
69 C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_AedgMeasures.rb
70 C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HelperMethods.rb
71 C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb
72 C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.lt2912/ApplyMeasureNow/UserScript/resources/OsLib_Schedules.rb
[NOTE]
You may have encountered a bug in the Ruby interpreter or extension libraries.
Bug reports are welcome.
For details: http://www.ruby-lang.org/bugreport.html
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
