OpenStudio does not start & SketchUp plugin load errors
Hello. I have a problem with running OpenStudio and SketchUp plugin in my laptop. I run Windows 10 x64 First i installed SketchUp 2017 and then OpenStudio 1.13.0 Open Studio showed a message that didn't found SketchUp 2016. I tried to open OpenStudio but it didn't open.Only the other 2 programms ran. (analysis tool). I unistalled both OpenStudio and SketchUp 2017 and then I installed SkecthUp 2016 and OpenStudio 1.13.0 again. When i opened SketchUp I show a message about the plug in guide and then it showed a message about loading errors. The OpenStudio doesn't open again.The two programms are installed in the same folder.
  • Windows 10 x 64
  • SketchUp 2016
  • OpenStudio 1.13.0
  • Installed in the same folder
  • OpenStudio does not open (Only the other two programms run (parameter analysis tool))
  • SketchUp shows Load Errors for the plugin
  • The OpenStudio extension in SketchUp is checked
Error Loading File C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb Error: #<errno::eacces: permission="" denied="" -="" c:="" users="" ΧΑΡΗΣ="" appdata="" local="" temp="" openstudio=""> C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:245:in mkdir' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:245:infu_mkdir' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:219:in block (2 levels) in mkdir_p' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:217:inreverse_each' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:217:in block in mkdir_p' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:203:ineach' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:203:in mkdir_p' C:/Program Files/OpenStudio 1.13.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:104:ininitialize' C:/Program Files/OpenStudio 1.13.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:526:in new' C:/Program Files/OpenStudio 1.13.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:526:in<module:openstudio>' C:/Program Files/OpenStudio 1.13.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:76:in <top (required)>' C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb:52:inload' C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb:52:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:inrequire' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:176:inregister_extension' C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:176:in `<top (required)&gt;'<="" p="">
Please help !! I have a deadline project running ! Thank you !
  • Windows 10 x 64
  • SketchUp 2016
  • OpenStudio 1.13.0
  • Windows 10 x 64
  • SketchUp 2016
  • OpenStudio 1.13.0
  • Windows 10 x 64
  • SketchUp 2016
  • OpenStudio 1.13.0
  • Windows 10 x 64
  • SketchUp 2016
  • OpenStudio 1.13.0
