Dear All,
Currently we are working on a refrigeration objects and try to evaluate coil performance at different part load conditions with the help of set of performance curves. Based on the predicted cooling load, we would like to use a different power and capacity curve for the refrigeration compressor. We've already prepared the curves and want the Compressor object to use the correct curve through Energy Management System (EMS) feature.
Any suggestions would be highly appreciated.
Thanks,
