No matter where I assign the construction, the following errors occur. (Eg. At the building level, space type level, space level, or at the sub surface level.) I thought this error was explained before the move to Unmet hours, but I do not see any post with the same problem. This has happened in other models I have started, but not every time.
I have also hard coded the construction name in the .osm file using Notepad++. However, the idf .err file still shows the blank entry. It is almost as if the fixed window construction lookup (hierarchy) is not assigning the construction at run time.
Any help is greatly appreciated.
* Severe * IP: IDF line~1316 Error detected in Object=FENESTRATIONSURFACE:DETAILED, name=SUB SURFACE 11
* ~~~ * Field [Construction Name] is required but was blank
------------- IDF Context for following error/warning message:
------------- Note -- lines truncated at 300 characters, if necessary...
------------- 1329 FenestrationSurface:Detailed,
-------------indicated Name=Sub Surface 12
------------- Only last 3 lines before error line shown.....
------------- 1330 Sub Surface 12, !- Name
------------- 1331 Window, !- Surface Type
------------- 1332 , !- Construction Name
