I've working on a clients system running Win7, system meets all the system requirements. Sketchup Pro 2016 locks up or responds slowly when the OpenStudio plug-in is utilized. Sketchup does not slow down when not using the plug-in. We have tried using the latest version of the Legacy OpenStudio Plug-in for Win7, Energyplus 8.4, Sketchup Pro 16, and OpenStudio 1.11. Using the Legacy OpenStudio Plug-in does not work at all errors opening OSM file. The OpenStudio Plug-in (not Legacy) opens the file but then bogs down in performance usually requiring to Sketchup to be closed from Task Manager. I have uninstalled and re-installed OpenStudio. I have copied the libeay32.dll and the ssleay32.dll files to the Sketchup Pro directory to ensure there was not a conflict with dll files between the OpenStudio and the Sketchup Pro.
Any suggestions has anyone else seen this?
