you can help me . what mean ?? warning : some outward facing angles of subsurfaces differ more than 30.0 degrees base surface. use output:Diagnostics,Display Extra Warnings;to show more details on individual surfaces.
| 1 | initial version |
| 2 | retagged |
| 3 | No.3 Revision |
| 4 | No.4 Revision |
you can help me .
what mean ?? What does the warning message mean:
warning : some outward facing Some Outward Facing angles of subsurfaces differ more than 30.0 degrees base surface.
and how do I fix it?
| 5 | No.5 Revision |
warning : Some Outward Facing angles of subsurfaces differ more than 30.0 degrees base surface.
use output:Diagnostics,Display Extra Warnings;to show more details on individual and how do I fix it?
| 6 | No.6 Revision |
| 7 | retagged |
warning : Some Outward Facing angles of subsurfaces differ more than 30.0 degrees base surface. use output:Diagnostics,Display Extra Warnings;to show more details on individual surfaces.
