I am new to openstudio and i am trying to run a office building simulation to determine Cooling and Heating energy consume. I a model to test, i posted it at this link.
When i simulate it crashes with fatal error saying the following messages:
Severe * IP: IDF line~45517 Error detected in Object=COIL:COOLING:WATER, name=COIL COOLING WATER 2 * ~~~ ** Field [Air Outlet Node Name] is required but was blank
Severe * IP: IDF line~45543 Error detected in Object=COIL:COOLING:WATER, name=HW CHW FOUR PIPE INDUCTION TERMINAL CHW CLG COIL * ~~~ ** Field [Air Inlet Node Name] is required but was blank
I dont know exactly how to fix it.
Please could you give me a help looking at my model and showing me how to fix it?
Thank you.
Best Regards.
Sergio
