I'm using openstudio defaults to create a model and i want to know window thickness in case of using single pane and if there is no default available how can i set that manually, regards!
| 1 | initial version |
| 2 | No.2 Revision |
I'm using openstudio defaults to create a model and i want to know window thickness in case of using single pane and if there is no default available how can i set that manually, regards!regards!!
| 3 | No.3 Revision |
I'm using openstudio defaults to create a model and i want to know window thickness in case of using single pane and if there is no default available how can i set that manually, regards!!
| 4 | No.4 Revision |
| 5 | No.5 Revision |
