How to create thermostat
What are my options for creating a custom Thermostats ThermostatSetpoint:DualSetpoint that I can access from the SketchUp plugin and assign when using the Space Attributes Button ?
I'd prefer not to write a measure, or otherwise get down and Ruby.
The object I am missing something obvious, because I imagine this trying to create is not an unusual requirement.a ThermostatSetpoint:DualSetpoint which references the heating and cooling setpoints.
This question relates object doesn't seem to OS >1.10 where the Thermostat is no longer be visible in the Inspector...OS App,nor the OS Inspector is that right? That seems to rule out editing an existing one from a library and also baking my own (without getting down to the Ruby). So I am curious how the building type templates in the New Model wizard are created and managed ?
