Hi,
Modeling a building with OPS interface, i found problems when intersect faces between zones (one above other), small surfaces created cause matching problems, this small surfaces are created when intersecting faces, how can i avoid this situation? or let the program work with these small surfaces? how can fix it when match in the drawing?
