Hi! I'm modeling my single zone building using OpenStudio. I'm having a problem with my HVAC system because sometimes the heating and the cooling coil are working at the same time.
In this example the cooling system starts and then stops for a little time, and the interior temperature is very far from the cooling setpoint.
The AVAC template I added to my model is a Packaged Rooftop Heat Pump.
I had an identical problem some weeks ago and I asked here in unmethours. At the time @rraustad suggested me to had another setpoint manager. Until the moment I didn't find how to add a setpoint manager in OpenStudio and I'm a little bit lost in this situation. Can you please explain me how to add a setpoint manager in my HVAC model? How can I solve this problem? Here is my model. Thank you
