Hello my Name is Adityo Dharmanto, I need your Help, There is an Error when i Run the simulation in OpenStudio Radiance. I make the simple building model in the Sketchup Make, and i export as OSM file. when i run the simulation theres an error, this is the Error Source.
[utilities.idf.Workspace] <1> URL Found in IDF: file:files/IDN_Surakarta_MN6.epw but no source could be located. [utilities.idf.WorkspaceObject] <0> Object of type 'Schedule:Constant' and named 'Always On Discrete', points to an object named OnOff from field 1, but that object cannot be located. [utilities.idf.WorkspaceObject] <0> Object of type 'Schedule:Constant' and named 'Always Off Discrete', points to an object named OnOff 1 from field 1, but that object cannot be located. [utilities.idf.WorkspaceObject] <0> Object of type 'Schedule:Constant' and named 'Always On Continuous', points to an object named Fractional from field 1, but that object cannot be located. [openstudio.runmanager.LocalProcess] <1> Starting LocalProcess: C:/Program Files/OpenStudio 1.10.0/share/openstudio/EnergyPlusV8-4-0/ExpandObjects.exe [openstudio.runmanager.LocalProcess] <1> Starting LocalProcess: C:/Program Files/OpenStudio 1.10.0/share/openstudio/EnergyPlusV8-4-0/energyplus.exe [openstudio.EpwFile] <0> Header start day of the week and actual start day of the week do not match in EPW file 'C:/Users/adityo dharmanto/AppData/Local/Temp/OpenStudio.yK5652/resources/run/1-UserScript-0/in/files/IDN_Surakarta_MN6.epw'. Data will be treated as typical (TMY) place Surakarta_IDN latitude -7.569 longitude -110.82 time_zone -105 site_elevation 165 weather_data_file_units 1 Script executing from: C:/Users/adityo dharmanto/AppData/Local/Temp/OpenStudio.yK5652/resources/run/1-UserScript-0 Found argument 'apply_schedules' with value 'Yes'. Found argument 'use_cores' with value 'Default'. Found argument 'rad_settings' with value 'Model'. Found argument 'image_type' with value 'Simple'. Found UserScript 'Radiance Daylighting Measure'. [Radiance Measure 2016-05-24 02:14:51 UTC]: Radiance multiprocessing features are not supported on Windows. [Radiance Measure 2016-05-24 02:14:51 UTC]: Using 1 core(s) for Radiance jobs [Radiance Measure 2016-05-24 02:14:52 UTC]: Adding path for local perl: C:\Program Files\OpenStudio 1.10.0\strawberry-perl-5.16.2.1-32bit-portable-reduced\perl\bin [Radiance Measure 2016-05-24 02:14:53 UTC]: Creating workflow [Radiance Measure 2016-05-24 02:14:54 UTC]: Running jobs in eplus_preprocess [Radiance Measure 2016-05-24 02:15:05 UTC]: OpenStudio to Radiance translation complete [Radiance Measure 2016-05-24 02:15:05 UTC]: Radiance run directory: 'C:\Users\adityo dharmanto\AppData\Local\Temp\OpenStudio.yK5652\resources\run\1-UserScript-0\radiance' [Radiance Measure 2016-05-24 02:15:06 UTC]: $ epw2wea "C:\Users\adityo dharmanto\AppData\Local\Temp\OpenStudio.yK5652\resources\run\1-UserScript-0\in\files\IDN_Surakarta_MN6.epw" wx\in.wea [Radiance Measure 2016-05-24 02:15:06 UTC]: Passing 101 calculation points to Radiance [Radiance Measure 2016-05-24 02:15:06 UTC]: Computing daylight coefficient matrices [Radiance Measure 2016-05-24 02:15:06 UTC]: $ oconv materials\materials.rad model.rad > octrees\model_dc.oct [Radiance Measure 2016-05-24 02:15:07 UTC]: Computing view matrix for uncontrolled windows (WG0) [Radiance Measure 2016-05-24 02:15:07 UTC]: $ oconv materials\materials.rad model.rad skies\dc_sky.rad skies\dc_sky.rad > octrees\model_WG0.oct [Radiance Measure 2016-05-24 02:15:07 UTC]: $ type numeric\merged_space.map | rcontrib -ab 10 -ad 65536 -as 512 -dj 1 -dp 1 -dt 0 -dc 1 -lw 1.52e-005
-I+ -fo -e MF:1 -f tregenza.cal -b tbin -bn Ntbins -o output\dc\WG0.vmx -m skyglow octrees\model_WG0.oct [Radiance Measure 2016-05-24 02:15:46 UTC]: Daylight coefficient matrices computed. [Radiance Measure 2016-05-24 02:15:46 UTC]: Performing annual daylight simulation(s) [Radiance Measure 2016-05-24 02:15:46 UTC]: $ gendaymtx -m 1 "wx\in.wea" > annual-sky.mtx [Radiance Measure 2016-05-24 02:15:48 UTC]: $ dctimestep output\dc\WG0.vmx annual-sky.mtx | rmtxop -fa -c 47.4 120 11.6 - > output\ts\WG0.ill [Radiance Measure 2016-05-24 02:15:51 UTC]: Merging window group daylight illuminance schedules to building daylight illuminance schedule [Radiance Measure 2016-05-24 02:15:51 UTC]: Adding uncontrolled window results [Radiance Measure 2016-05-24 02:15:51 UTC]: Model has no controlled window groups [Radiance Measure 2016-05-24 02:15:51 UTC]: $ rmtxop -fa output\ts\WG0.ill -t | getinfo - > "output\ts\merged_space.ill" [Radiance Measure 2016-05-24 02:15:52 UTC]: Parsing daylighting results [Radiance Measure 2016-05-24 02:15:52 UTC]: An error has occurred; no results for space 'Space_101'. [Radiance Measure 2016-05-24 02:15:53 UTC]: An error has occurred; no results for space 'Space_101'. [Radiance Measure 2016-05-24 02:15:53 UTC]: An error has occurred; no results for space 'Space_101'. [Radiance Measure 2016-05-24 02:15:53 UTC]: An error has occurred; no results for space 'Space_101'. [Radiance Measure 2016-05-24 02:15:53 UTC]: An error has occurred; no results for space 'Space_101'. [Radiance Measure 2016-05-24 02:15:53 UTC]: Returning annual results [Radiance Measure 2016-05-24 02:15:53 UTC]: envPeriod = 'RUN PERIOD 1' [Radiance Measure 2016-05-24 02:16:00 UTC]: Processing space 'Space_101' [Radiance Measure 2016-05-24 02:16:01 UTC]: Writing Radiance results file [Radiance Measure 2016-05-24 02:16:01 UTC]: Writing Radiance results database [Radiance Measure 2016-05-24 02:16:37 UTC]: Updating lighting load schedules [Radiance Measure 2016-05-24 02:16:38 UTC]: ThermalZone 'Thermal Zone 1' illuminance setpoint is: 500 lux [Radiance Measure 2016-05-24 02:16:38 UTC]: Thermal Zone 'Thermal Zone 1' lighting power is: 269 W [Radiance Measure 2016-05-24 02:16:38 UTC]: Calculating Daylight Metrics for Space 'Space_101' [Radiance Measure 2016-05-24 02:16:41 UTC]: Warning: Daylight Autonomy for building is zero, check daylighting control point(s) setup.
And i use the OpenStudio Radiance like this Tutorial https://www.youtube.com/watch?v=LAvhO777pPU
I do same like that tutorial. I use the laptop Lenovo, Windows 10, Openstudio 1.10 and also install the Radiance and Daysim. i hope you guys can help to solve this problem. Thankyou
