I am modelling photovoltaic's in EnergyPlus based off of the Example File 'ShopWithPVandStorage.idf'. In the component ElectricLoadCenter:Generators you set a 'Generator Rated Electric Power Output' which I assumed would be the max output the generator could produce. But when I set this value to 0 there was still photovoltaic energy production even though I had rated the power output to 0 W. This leads me to guess that there is some fixed value EnergyPlus is assuming for the output since I also tested with 1000 W and 2000 W and three cases(including 0 W) resulted in the same energy production. Is there another spot I need to set the generator power output?
