I'm getting this error when running a T-24 compliance calculation. All these errors are in the Baseline Case. How am I supposed to fix these? Any thoughts? Is it because i did something in the Proposed Case? Thanks.
*2016-May-05 09:51:45 - EnergyPlus Severe Error(s) (24): 2016-May-05 09:51:45 - 1: Sizing: Coil:Cooling:DX:TwoSpeed "BASESYS12A COILCLG": Rated air volume flow rate per watt of rated total cooling capacity is out of range. Min Rated Vol Flow Per Watt=[4.027E-005], Rated Vol Flow Per Watt=[3.757E-005], Max Rated Vol Flow Per Watt=[6.041E-005]. See Input Output Reference Manual for valid range.
