I need to make a hole on the surface of my sun shading,the problem is that I make like the first image below but when I reopen my OS model the hole is disappeared!(and the sun shading is without hole like second image below.)
| 1 | initial version |
| 2 | No.2 Revision |
| 3 | No.3 Revision |
Thanks in advance for any guidance!
| 4 | No.4 Revision |
I need to make a hole on the surface of my sun shading,the problem is that I make it like the first image below but when I reopen my OS model the hole is disappeared!(and the sun shading is without hole like second image below.)
| 5 | No.5 Revision |
I need to make a hole on the surface of my sun shading,the problem is that I make it like the first image below but when I reopen my OS model the hole is disappeared!(and the sun shading is without the hole like second image below.)
