I made an building energy model by OpenStudio v1.10.0 and would like to use the unmet hours troubleshooting measure to reduce the unmet hours according to the following instruction: https://unmethours.com/question/359/what-are-your-techniques-for-reducing-unmet-hours/#362
The model can run successfully. However, the running failed after adding that measure. The details is showed as the following screen shot.
Does anyone get this problem before?
