There are four SurfaceConvectionAlgorithm:Inside and five SurfaceConvectionAlgorithm:Outside options for calculating surface convection in EnergyPlus. The default for inside is TARP and for outside is DOE-2 and I've never really considered trying the other options.
My question is what are the differences between the algorithms (in theory and in practice)?
Do some run faster than others?
Are some better-validated than others?
Do some capture different effects?
Are some more robust to errors/inaccuracies in input parameters?
Essentially, under what situations would it make sense to use anything other than the default options?
