Hello, i run windows 10 64 bits. I install first sketchup then energy plus and then openstudio, before i install openstudio sketch up runs fine.After openstudio installation, openstudio wont start at all and sketch up comes up with the following. I have tried 1 month ago with previous openstudio versions and faced the same problem.
Thanks in advance ithermos
Error Loading File C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb
Error: #<errno::eacces: permission="" denied="" -="" c:="" users="" Γιάννης>="" c:="" program="" files="" sketchup="" sketchup="" 2016="" tools="" rubystdlib="" fileutils.rb:245:in="" <code="">mkdir'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:245:infu_mkdir'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:219:in block (2 levels) in mkdir_p'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:217:inreverse_each'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:217:in block in mkdir_p'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:203:ineach'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:203:in mkdir_p'
C:/Program Files/OpenStudio 1.11.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:95:ininitialize'
C:/Program Files/OpenStudio 1.11.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:517:in new'
C:/Program Files/OpenStudio 1.11.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:517:in<module:openstudio>'
C:/Program Files/OpenStudio 1.11.0/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:67:in <top (required)>'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb:43:inload'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb:43:in <top (required)>'
C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:inrequire'
C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:167:inregister_extension'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:167:in `<top (required)>'<="" p="">
