I am running a model with ideal air loads controlling only the temperature setpoints, but I was getting latent cooling loads even though I have not set any humidity limits.
I need to define a temperature range and check its effect on the energy consumption and in the relative humidity, but without affecting the humidity ratio. Is this possible?
