If my building has a room with a door that open into a corridor. The room and corridor are two separate zones, then how your comment fit into this situation? I have to draw door in both zones (corridor and room)?
![]() | 1 | initial version |
![]() | 2 | No.2 Revision |
If my building has a room with a door that open opens into a corridor. The corridor, and the room and corridor are two separate zones, then how your comment fit into this situation? do I model this? Do I have to draw the door in both zones (corridor (the corridor and the room)?
![]() | 3 | No.3 Revision |
If my building has a room with a door that opens into a corridor, and the room and corridor are two separate zones, how do I model this? Do I have to draw the door in both zones (the corridor and the room)?
![]() | 4 | retagged |
