Hi everyone, I'm using energyplus dan I have a problem when using unitary system template. I don't see cooling load at output result. I'm not using for heating, just for cooling and cooling setpoint is 24C. Please see my attachment file. What should I change in idf file in order to get cooling load at the output result?
https://www.dropbox.com/s/3j2rz77dcx9f357/SBM_4th%20-%20Zero%20Heating%2024C%20Reschedule.idf?dl=0
