I am wondering which setpoint manager I should be using for AHU supply air temperature. Basically I originally modelled the building with a SetpointManagerScheduled for a constant temperature supplied by the AHU for the entire run period. I know have further information that the supply air temperature directly from the AHU can be between 13 and 18C. Basically teh temperature supply would depend on the zone requirements as expected.
Should I be using the SetpointManagerScheduledDualSetpoint? If so will the program automatically determine the supply air temperature based on the zone requirements? ie. will it supply the 18C during the heating requirement days and 13C on the cooling requirement days?
Thanks in advance for the help.
