Hey, I want to compare Eplus-simulation-results with other Tools (Trnsys, etc.). For the shading models i got the following parameters:
"Shading-factor": 96,3% of the radiation are not transmitted when shading is active + a schedule for shading with values between 0 and 1. The other tools don't need input parameter like: Reflectance, Infrared Hemispherical, etc. My questions: Are these proper values for WindowsMaterial:Shade?
WindowMaterial:Shade,
Shade, !- Name
0.036, !- Solar Transmittance {dimensionless}
0.9, !- Solar Reflectance {dimensionless}
0.036, !- Visible Transmittance {dimensionless}
0.9, !- Visible Reflectance {dimensionless}
0.2, !- Infrared Hemispherical Emissivity {dimensionless}
0.036, !- Infrared Transmittance {dimensionless}
0.002, !- Thickness {m}
1, !- Conductivity {W/m-K}
0.05, !- Shade to Glass Distance {m}
0.5, !- Top Opening Multiplier
0.5, !- Bottom Opening Multiplier
0.5, !- Left-Side Opening Multiplier
0.5, !- Right-Side Opening Multiplier
; !- Airflow Permeability {dimensionless}
Thank you very much!
