ExpandObjects Started. No expanded file generated. ExpandObjects Finished. Time: 0.021 Script executing from: /private/var/folders/83/4zd9hcsj3h1_mj7k3bvcqwz80000gn/T/OpenStudio.pfp628/resources/run/3-UserScript-0 Found argument 'measures_json' with value '[{"arguments":{},"measure":"/Applications/OpenStudio 1.9.0/OpenStudio.app/Contents/share/openstudio-1.9.0/pat/Measures/StandardReports/measure.rb"}]'. Found UserScript 'Report Request'. Looking for building_summary_section (Model Summary) Boolean, Required Value: (true) Looking for annual_overview_section (Annual Overview) Boolean, Required Value: (true) Looking for monthly_overview_section (Monthly Overview) Boolean, Required Value: (true) Looking for utility_bills_rates_section (Utility Bills/Rates) Boolean, Required Value: (true) Looking for envelope_section_section (Envelope) Boolean, Required Value: (true) Looking for space_type_breakdown_section (Space Type Breakdown) Boolean, Required Value: (true) Looking for space_type_details_section (Space Type Summary) Boolean, Required Value: (true) Looking for interior_lighting_section (Interior Lighting Summary) Boolean, Required Value: (true) Looking for plug_loads_section (Plug Loads Summary) Boolean, Required Value: (true) Looking for exterior_light_section (Exterior Lighting) Boolean, Required Value: (true) Looking for water_use_section (Water Use Equipment) Boolean, Required Value: (true) Looking for hvac_load_profile (HVAC Load Profiles) Boolean, Required Value: (true) Looking for zone_condition_section (Zone Conditions) Boolean, Required Value: (true) Looking for zone_summary_section (Zone Overview) Boolean, Required Value: (true) Looking for zone_equipment_detail_section (Zone Equipment Detail) Boolean, Required Value: (true) Looking for air_loops_detail_section (Air Loops Detail) Boolean, Required Value: (true) Looking for plant_loops_detail_section (Plant Loops Detail) Boolean, Required Value: (true) Looking for outdoor_air_section (Outdoor Air) Boolean, Required Value: (true) Looking for cost_summary_section (Cash Flow) Boolean, Required Value: (true) Looking for source_energy_section (Site and Source Summary) Boolean, Required Value: (true) Looking for schedules_overview_section (Schedule Overview) Boolean, Required Value: (true) result = true Processed 1 base script and 0 merged scripts EnergyPlus Starting EnergyPlus, Version 8.3.0-6d97d074ea, YMD=2015.12.01 08:16 Processing Data Dictionary Processing Input File Initializing Simulation Reporting Surfaces Beginning Primary Simulation Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/01 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=01/21 Continuing Simulation at 01/21 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=02/10 Continuing Simulation at 02/10 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=03/02 Continuing Simulation at 03/02 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=03/22 Continuing Simulation at 03/22 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=04/11 Continuing Simulation at 04/11 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=05/01 Continuing Simulation at 05/01 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=05/21 Continuing Simulation at 05/21 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=06/10 Continuing Simulation at 06/10 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=06/30 Continuing Simulation at 06/30 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=07/20 Continuing Simulation at 07/20 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=08/09 Continuing Simulation at 08/09 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=08/29 Continuing Simulation at 08/29 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=09/18 Continuing Simulation at 09/18 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=10/08 Continuing Simulation at 10/08 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=10/28 Continuing Simulation at 10/28 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=11/17 Continuing Simulation at 11/17 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=12/07 Continuing Simulation at 12/07 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=12/27 Continuing Simulation at 12/27 for RUN PERIOD 1 Writing tabular output file results using HTML format. Computing Life Cycle Costs and Reporting Writing final SQL reports EnergyPlus Run Time=00hr 00min 3.05sec [BOOST_ASSERT] <2> Assertion ok failed on line 108 of std::string openstudio::toNeatString(double, unsigned int, bool) in file /Users/alexswindler/OpenStudio/openstudiocore/src/utilities/core/StringHelpers.cpp. [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect [openstudio.model.ConstructionBase] <1> Could not resolve matched surface construction conflicts between surfaces '1', and '1', area calculation may be incorrect Script executing from: /private/var/folders/83/4zd9hcsj3h1_mj7k3bvcqwz80000gn/T/OpenStudio.pfp628/resources/run/6-UserScript-0 Found UserScript 'OpenStudio Results'.
