I am struggling to correctly model a laboratory ventilation system with multiple vav fume hoods in Openstudio. I have 8 hoods with vav sashes and I've made a schedule similar to a lighting schedule that I want to apply to the peak fine exhaust rate to simulate a variable number of open hood sashes through a typical day. I am using a vav air handler with dx cooling coil and hot water heating coil in the ahu and hw reheat coils for the lab zones. Each lab contains 8 hoods and each hood has a maximum of 1200 cfm of exhaust. I am using a manifolded exhaust system rather than one exhaust fan per hood. I am constraining my exhaust system to a maximum flow of 19200 cfm and a minimum flow of 15000 cfm so that I keep a minimum exhaust stack velocity (so not a large degree of exhaust fan energy savings from vav hoods, but I will save a lot on makeup air conditioning). I placed a variable speed exhaust fan on the exhaust node at the air handling unit. Do I hard size the exhaust fan min and max cfm and apply the fine hood schedule? Do I apply the same hard settings and/or schedule to my supply fan? Also because I have no return duct I turned off economizer in the ventilation control object for the ahu. I also noticed that there are some zone flowrate control options for each of my lab zones but I don't know whether to use those or the fan flow controls.
