I developed a model with Packaged Terminal Heat Pump Air Loop with a Variable Speed Fan (Air Handler Unit). However, the model gives constant hourly fan energy values and this does not match the actual data. How do I get the fan energy to vary.
| 1 | initial version |
| 2 | No.2 Revision |
How do I get the fan energy to vary.vary.
Attached is the hourly energy consumption of the measure and simulated model.
| 3 | No.3 Revision |
| 4 | No.4 Revision |
link textI developed a model with Packaged Terminal Heat Pump Air Loop with a Variable Speed Fan (Air Handler Unit).
| 5 | No.5 Revision |
The link to the model is link text
| 6 | No.6 Revision |
I developed a
The Here is the link to the model is
link textOpenStudio Model
