Error when adding hvac system to model
Hi all,
I have a model that runs fine without an HVAC system but when I add even the simplest HVAC system and run a simulation I get 5 errors and the following message in the tree view:
"EnergyPlus Starting
EnergyPlus, Version 8.3.0-6d97d074ea, YMD=2015.11.03 14:43
Processing Data Dictionary
Processing Input File
**FATAL:IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
EnergyPlus Run Time=00hr 00min 0.46sec"
I know this is a very generic error but I was hoping someone here might have a few things for me to try. I tried many different settings, made sure everything looks similar to a model with an HVAC system that produces results but could not make it work.
Any help is appreciated.
Thanks!
Jim
Hi all,
Thanks!
Jim
