Bug Report - Thermostat
Today I was running a simulation on Energy Plus and I faced a bug when I removed one of the thermostats from a specific thermal zone (. Energy Plus took out all the thermostats I had in different thermal zones.
To fix that, I had to open the SketchUp file and select all thermal zones I wanted the thermostat back, click on the tab Set Attributes for Selected Spaces, and then change the Set Parent Thermal Zone's - Thermostat to the thermostat I wanted.
click to hide/show revision 2
No.2 Revision
Today I was running a simulation on Energy Plus OpenStudio and I faced a bug when I removed one of the thermostats from a specific thermal zone (. Energy Plus zone. OpenStudio took out all the thermostats I had in different thermal zones.
Today I was running a simulation on OpenStudio and I faced a bug when I removed one of the thermostats from a specific thermal zone. OpenStudio took out all the thermostats I had in different thermal zones.
click to hide/show revision 4
No.4 Revision
Today I was running a simulation on OpenStudio and I faced a bug when I removed one of the thermostats from a specific thermal zone. OpenStudio took out all the thermostats I that had the same name, eventhough they were in different thermal zones.zoner.
To fix that, I had to open the SketchUp file and select all thermal zones I wanted the thermostat back, click on the tab Set Attributes for Selected Spaces, and then change the Set Parent Thermal Zone's - Thermostat to the thermostat I wanted.wanted. Hopefully it worked.
[URL=http://img.gforum.tv/ver.php?i=09e4a555b9d9464c1390fd199729a9a6415ead57.jpg][IMG]http://img.gforum.tv/img/09e4a555b9d9464c1390fd199729a9a6415ead57.jpg[/IMG][/URL]
click to hide/show revision 5
No.5 Revision
Today I was running a simulation on OpenStudio and I faced a bug when I removed one of the thermostats from a specific thermal zone. OpenStudio took out all the thermostats that had the same name, eventhough they were in different thermal zoner.
To fix that, I had to open the SketchUp file and select all thermal zones I wanted the thermostat back, click on the tab Set Attributes for Selected Spaces, and then change the Set Parent Thermal Zone's - Thermostat to the thermostat I wanted. Hopefully it worked.
click to hide/show revision 6
No.6 Revision
click to hide/show revision 7
No.7 Revision
