-Sky condition changes -sun's angle changes
But on what basis i can take 3 latitudes?? - is there a theory of change in inclination is prominent with 4 degree change in latitude?? Please help
![]() | 1 | initial version |
![]() | 2 | retagged |
![]() | 3 | retagged |
![]() | 4 | No.4 Revision |
I have to select 3 cities for daylight performance.
@Neal : On what basis I select Delhi,Ahmedabad and Chennai.
1. Different latitudes (Delhi: 28.6100° N, 77.2300° E,Ahmedabad: 23.0300° N,72.5800° E,Chennai13.0839° N, 80.2700° E) 2 Change in sun's inclination
But I want to understand if I am using a newly developed daylight device, how will i compare this for all the three latitude cities. there should -Sky condition changes
-sun's angle changes But on what basis i can take 3 latitudes??
- is there a theory of change be something common in select 3 latitude cities for simulations? inclination is prominent with 4 degree change in latitude??
Please helpweather data.
![]() | 5 | retagged |
@Neal : On what basis I select Delhi,Ahmedabad and Chennai. 1. Different latitudes (Delhi: 28.6100° N, 77.2300° E,Ahmedabad: 23.0300° N,72.5800° E,Chennai13.0839° N, 80.2700° E) 2 Change in sun's inclination But I want to understand if I am using a newly developed daylight device, how will i compare this for all the three latitude cities. there should be something common in weather data.
![]() | 6 | retagged |
![]() | 7 | retagged |
