I'm attempting to model in eQuest a school that uses a simplified method of DCV.
In each classroom there is a vacancy sensor that, if it does not detect motion for a set period of time, generates a signal that is used to both turn off the lights in the classroom and also shut its supply air damper.
I'm wondering: is there some sort of method that can be used to schedule zone-level airflow that I could use to model this? What I'd like to do is simply schedule these dampers to close during the school's unoccupied hours. I see that eQuest/DOE has the ability to schedule minimum airflow at the zone level, but really what I need is the ability to schedule the maximum airflow.
Any help would be much appreciated. I'd also be open to other approaches to modelling this.
