Problem plugin OS 1.8.0 - Sketchup 2015 on xubuntu 15.04 (32 bits)
Hi all,
i had to install xubuntu 15.04 a few days ago and i'm looking for a way to install OS 1.8 with sketchup 2015. I'm with a 32 bits version of xubuntu, and using wine 1.7.44.
Sketchup and OpenStudio are going well, but i'm still dealing with matters according to OS plugin... I'm installing the 32 bits versions, and Ruby 2.0.
My Wine cfg is windows 7.
So the problem is that, after installing OS 1.8.0, a message tells me that OS 1.8 64 bits is incompatible with Sketchup 2015 32 bits. To see what would happen with an OS 64 bits version, i installed one, and the message tells me the contrary: OS 1.8 32 bits is incompatible with Sketchup 2015 64 bits.
So it's funny, but i'm loosing my patience, and i'd like to know if some of you have an idea. I don't know if it comes from the libraries in Wine, the way i have to install ruby, etc.
For example: ruby --version ruby 2.1.2p95 (2014-05-08) [i386-linux-gnu] And in the file OpenStudio-config.rb we have “if RUBY_PLATFORM=='i386-mingw32' then require 'C:\Program Files\OpenStudio 1.7.5\Ruby\openstudio' else raise LoadError, '32-bit OpenStudio is incompatible with 64-bit SketchUp 2015'
Well, that's it. I'm lost and i really hope some one of you guys could give me some tips... I guess it's not that bad...
Thanks a lot!
Hi all,
Thanks a lot!
Hi all,
Thanks a lot!
