Hi everyone,
I am trying to directly calculate the energy balance (sensible heating/cooling) for the air node in a MixedAir model to determine the exact heating/cooling load components.
To evaluate the heat balance, I considered the following key factors:
1) Internal Convective Heat Gain Rate
2) Surface Convection Rate
3) Outdoor Air Transfer Rate
4) System Air Transfer Rate
Based on this, I assumed the following balance equation:
System Air Transfer Rate = Internal Convective Heat Gain Rate + Surface Convection Rate + Outdoor Air Transfer Rate
Here is how I mapped these factors to the specific Modelica output variables in my model:
Internal Convective Heat Gain Rate:
roo.air.QCon_flowSurface Convection Rate:
roo.air.convConExt.Q_flow+roo.air.convConExtWin.Q_flow+roo.air.convConWin.air.Q_flow+roo.air.convConBou.Q_flow
(For context, my zone model consists of 1 exterior wall, 4 windows, 4 exterior walls with windows, and 1 floor).
Outdoor Air Transfer Rate:
roo.port[2].h_outflow*roo.port[2].m_flowSystem Air Transfer Rate:
preHea.Q_flow
I plotted the sum of the components (1 + 2 + 3) and compared it against the system air transfer rate (4) to verify the energy balance. However, the graphs do not perfectly match, and there is a noticeable discrepancy between the two.
Could anyone advise on what I might be missing?
