EPW Warnings in BEOpt 3.1.1
Why am I receiving these errors? I used the standard weather data provided.
3.xml: Warning: No EPW design conditions found; calculating design conditions from EPW weather data. 1.xml: Warning: No EPW design conditions found; calculating design conditions from EPW weather data. 2.xml: Warning: No EPW design conditions found; calculating design conditions from EPW weather data. 4.xml: Warning: BackupHeatingActiveDuringDefrost does not apply when system has separate backup heating. 4.xml: Warning: No EPW design conditions found; calculating design conditions from EPW weather data.
4.xml:  Warning: No EPW design conditions found; calculating design conditions from EPW weather data.data.
Thanks
