Modelling residential air‑source heat pump in DesignBuilder/EnergyPlus: system setup, performance curves, and validation against field data.
I’m modelling a residential air‑source heat pump in DesignBuilder/EnergyPlus and need one‑to‑one support with system setup, performance curves, and validation against field data.
I’m looking for someone with experience in HVAC modelling, heat pumps, and EnergyPlus coil performance curves.
Are you available for short paid sessions (online) to guide me through the modelling steps
