Weather file not running in BEopt
We found some weather files predicting future weather rather than relying on past weather data. I was able to put them in the weather file for Beopt, so they show up in the menu and I can even see the data in the data viewer but when I try to use it to run a simulation it gives me this error "No such file or directory @rb_sysopen-C:/Users/pmdon/Documents/BEopt_3.0.1/TEMP1/1/run/../../USA_OR_PDX_ETONZF_Future-cache.csv"
and it cannot run the simulation.
This seems to be a temporary file that Beopt makes while running a simulation. If it is open during the simulation I see the weather file show up there.
Maybe there is something wrong with the weather file? (although I can see it in the data viewer) I got it from here https://www.energytrust.org/commercial/new-buildings/net-zero-grants/net-zero-fellow-joel-good/
