Create DOE Prototype Building-Supermarket
Hi, I'm looking to generate some prototype SuperMarket buildings using the "Create DOE Prototype Building" measure. I modified the measure by adding SuperMarket to the "building_type" choices list in the measure and I was able to generate some models using the ASHRAE template but not the 1980 and 1980-2010 vintages.
Do the older vintages exist for the SuperMarket building type.
This is the error I get for ""DOE Ref Pre-1980"
           STDERR:
     Failed to run workflow. Last Error:
      Found error in state 'OpenStudioMeasures' with message: 'Runner error: Measure 'C:/openstudio-3.10.0/Examples/compact_osw/measures/create_DOE_prototype_building/measure.rb' reported an error with [SWIG director method error. ArgumentError: invalid null reference Expected argument 1 of type openstudio::model::RefrigerationCompressor const &, but got NilClass nil
            in SWIG method 'addCompressor'
Traceback (most recent call last):
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.refrigeration.rb:421:in `addCompressor'
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.refrigeration.rb:421:in `block in model_add_refrigeration_system'
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.refrigeration.rb:419:in `each'
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.refrigeration.rb:419:in `model_add_refrigeration_system'
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.Model.hvac.rb:426:in `block in model_add_hvac'
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.Model.hvac.rb:15:in `each'
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.Model.hvac.rb:15:in `model_add_hvac'
:/ruby/3.2.0/gems/openstudio-standards-0.8.2/lib/openstudio-standards/prototypes/common/objects/Prototype.Model.rb:54:in `model_create_prototype_model'
C:/openstudio-3.10.0/Examples/compact_osw/measures/create_DOE_prototype_building/measure.rb:174:in `run']'
Thanks, Cameron
           STDERR:
Thanks, Cameron
